V5 installation
I just recently tried to install V5 of bricscad and received the following error.crc error: The file c:\program files\bricscad\R18toR15.dll doesn't match the file in the set-up's .cab file. The medium from which you are running the setup may be corrupted; contact your software vendor.I hit ignore and the software continued installing. I was wondering if the file that I have is corrupted or if that file isn't necessary. The software works, but I don't want to run into a problem down the road because that file wasn't installed properly. Thank you.
This problem doesn't appear in the current releases (version 5.0.0008) Classic and Pro.So it seems that your installset is corrupt because of a download problem.I suggest to remove the corrupt installset from your machine and to download it again.
0
