HPGL/2 Plot files
Has anyone found a driver that will generate correct hpgl-2 plot file output from Intellicad? The HP designjet drivers are almost perfect, but sadly do not properly support ttf fonts.
Welcome!
It looks like you're new here. Sign in or register to get started.
  • maybe it's a silly point, but have you tried to download the latest HP driver for your operating system?
  • If it won't create the plot file properly, that suggests it would not plot the fonts directly either.
  • I'm bumping this hoping for more feedback. As I said, the current HP drivers work perfectly EXCEPT they distort the ttf font output. I find it very odd nobody else mentions this problem anywhere, even google draws a blank. There is no better way to ship a drawing to a plotting service than as a hpgl/2 file, for us it is a must have. In fact this is more or less the only reason why we maintain an Acad license at our office (acad has native hpgl/2 drivers which can't be used by Bricscad)There is a generic HP hpgl/2 plotter driver that ships with Windows, which produces correct looking output. Unfortunately it generates files 10x the size of a file created in Acad. It also doesn't support custom paper sizes. Both these factors make it rather useless. I have tried windows plotter drivers from Encad and Oce, but am unable to produce hpgl/2 output from these (which is odd, since the Oce 9400 driver is my preferred plotter in Acad)I had a look at the Trixsystems site, as suggested above. I can only find pdf>hpgl conversion tools there, which is not what I'm looking for. In addition the pricing was ridicolous.Thanks for any suggestion you might have.
Welcome!
