Counting the occurrences of unique atoms
Is there a better way to count the occurrences of unique atoms in a list ?
Here is my code:
(defun c:fff() ;fff is just easy to press on a keyboard.
(setq aa '(1 1 1 2 2 2 2 3 3 3 3 3)) ; The test set of atoms
(setq bb '()) ;A secondary list to hold aa again for iterating throuh
(setq cc '()) ;This will be the dotted pair of atom and its count
(setq dd '()) ;The final list of all atoms and their counts
(setq ee '()) ;Just one of each unique atom and its count
(setq bb (append aa bb)) ;load aa int bb
(foreach xx aa
(setq ctr 0) ; A counter used to count the quantity of eacy uniuqe atom occurance
(foreach yy bb ;compare each item in aa to all of the items from aa copied to bb
;and move the counter up each time one occurs
(if (= xx yy)
(setq ctr (1+ ctr))
(setq cc (cons xx ctr)) ;create dotted pare of each atom and its number of occurances
(setq dd (cons cc dd)) ;pass the dotted pairs to a list
(foreach xx aa
(if (not (assoc xx ee)) ;only add the pairs form dd to ee if thay are not already in ee
(setq ee (cons (assoc xx dd) ee))
(print "ee") (print ee) (princ)
)I don't know many of the vl codes, so perhaps it is possible to do this with just one function ?
Sorry about the weird format. The code format did that. Here it is againDFLY said:Hello
Here is my code:(defun c:fff() ;fff is just easy to press on a keyboard. (setq aa '(1 1 1 2 2 2 2 3 3 3 3 3)) ; The test set of atoms (setq bb '()) ;A secondary list to hold aa again for iterating throuh (setq cc '()) ;This will be the dotted pair of atom and its count (setq dd '()) ;The final list of all atoms and their counts (setq ee '()) ;Just one of each unique atom and its count (setq bb (append aa bb)) ;load aa int bb (foreach xx aa (setq ctr 0) ; A counter used to count the quantity of eacy uniuqe atom occurance (foreach yy bb ;compare each item in aa to all of the items from aa copied to bb ;and move the counter up each time one occurs (if (= xx yy) (setq ctr (1+ ctr)) ) ) (setq cc (cons xx ctr)) ;create dotted pare of each atom and its number of occurances (setq dd (cons cc dd)) ;pass the dotted pairs to a list ) (foreach xx aa (if (not (assoc xx ee)) ;only add the pairs form dd to ee if thay are not already in ee (setq ee (cons (assoc xx dd) ee)) ) ) (print "ee") (print ee) (princ) )
(foreach xx aa
(if (= xx yy)
(setq ctr (1+ ctr))
(foreach xx aa
)0 -
; (count_atoms '(1 1 1 2 2 2 2 3 3 3 3 3)) (defun count_atoms (lst / fnd res) (foreach itm lst (if (setq fnd (assoc itm res)) (setq res (subst (cons itm (1+ (cdr fnd))) fnd res)) (setq res (cons (cons itm 1) res)) ) ) (reverse res) )0 -
Wow! Thanks. So much to digest from such a small script. I didn't know I could cons an atom with nil.Roy Klein Gebbinck said:; (count_atoms '(1 1 1 2 2 2 2 3 3 3 3 3)) (defun count_atoms (lst / fnd res) (foreach itm lst (if (setq fnd (assoc itm res)) (setq res (subst (cons itm (1+ (cdr fnd))) fnd res)) (setq res (cons (cons itm 1) res)) ) ) (reverse res) )0 -
Nil is special. It is both an atom and an empty list:
(atom nil) => T (listp nil) => T (= nil '()) => T
0
