BIMSECTION DESTINATION FILE
Hallo
I am using bimsection for a small project and have a few questions:
Luca
- can I use as a destination file the same file I am using for modelling and cutting sections ?this will allow to have a self contained destination file for 2d and 3D. will this create any conflict ?
- sometime the section markers disappear in the drawing ? is this a bug or how can I get them back ?
Luca
0
Hi Luca,
this will probably initially work but it is not intended to use it in this way and we can not guarantee any BIM functionality working correct (bimsectionupdate, bimtag, callouts...). We can also not give any support on this workflow. So our recommendation would be not to use it in this way.
The problems you have with the callouts, is this in the workflow you describe. With a sectionplane referring to the model drawing?
regards,
Piet0 -
Hallo
thanks for the feedback - Yes section tags missing happens with this workflow.
it may be related I do not know why as I assumed they are generated from a tremplate
regards
Luca0
