Will V21 run on Mac Os ventura (MacOs 13)
Has anyone tried wether this is working?
I've avoided updating my OS since I don't know wether it'll work afterwards.
  • I'm on M1 Mac and Ventura since the first Public Beta.
    I do not see any special Ventura or Apple ARM problems,
    just the standard Mac and Linux issues.
  • No idea on V21, but V23 is largely solid. Its not quite as smooth an experience as my windows machine and there are some oddities, but it works and is stable.
    Just to be clear: do you also run V21?
    (Yes, I know all about those Mac/Linux oddities).
  • Michael Mayer
    edited February 2023
    Sorry, I totally missed the V21 in the title.
    I am on V23 !
    But also worked a lot with V22. Same, NO noticeable issues with V22.
    But of course that will not help if you are interested in V21.
    So I would not risk it if avaoidable.
    macOS 11 Big Sur had a lot of changes that caused 3D/CAD App problems,
    macOS 12 was mild but with Ventura i noticed again some new problems
    in early releases of other Software (e.g. Vectorworks).
    Their latest 2 Versions are fixed by service packs meanwhile, while previous
    versions won't get such updates anymore.
  • Ok, seems like I should rest my case. (If someone has the possibility to download V21 and try I'd be most grateful.) Thanks.
