What is the UPDATE procedure ?
I noticed an UPDATE (**not Upgrade **) is available but I don't seem to be able to find any information on the specific procedure to install it. Is it the same as an Upgrade , where I need to deactivate the license , install new software then reactivate the license ? Or will the downloaded UPDATE file simply update my installed version ?
Thank you very much ![]()
If it is an only Update, like V21.1.01 to V21.2.01,
you just install it and it will update.If it is an upgrade, like from V20.2.01 to a V21.1.01,
you will also just install it, but you will need a new License number available
to activate it. Which you will get usually by buying an Upgrade or by having
Maintenance to find in your Accounts Licensing Information.
And with first start, new BC will ask you if you want to migrate Settings from
previous detected version.That new License number will now also run all your previous BC releases that
you may still have installed on your machine, or intend to install beside the latest
release.0 -
Thank you. I need to just update. I am going from 21.1.04 to 21.2.02-1
I am assuming the BRICSYS should NOT be running at the time of the update.0 -
Yes, closing Bricscad before updating is a good idea.
(I think a good Software updater would warn and ask for closing anyway)0 -
Again , thank you very much. I was able to update my instillation successfully. Here are a few things I learned:
1.) System must be connected to the internet , Ethernet is best.
2.) All other apps must be off , not minimized , off , including BRISCAD
3.) Use the Windows "RUN" app to execute the msi file , after its downloaded
4.) Agree to whatever default settings come up when the upgrade asks a question.
5.) Read thru the changes before you run BRICSCAD , there are a lot of changesThat's about it. It remembered all my setting and where my work was.
Works great ! I just wish some of this info was somewhere on the website
or maybe in the app itself. Especially considering that there is an
UPDATE line on the HELP dropdown menu.0 -
It is ridiculous that you cannot see from within the BricsCad application that an update/upgrade is available and that is not possible to install the update from within the application. You cannot even do an update/upgrade from within your account on the licences page.0
Absolutely - there's so many questions and difficulties that constantly arise, much of which Support has to spend time answering. There must be a recommended procedure and variants, which should be in an extended Help. It's a black art, which only the old hands can have learned, by bitter experiernce!No1vectorman said:I just wish some of this info was somewhere on the website
Or an email to all license holders, as does happen for major upgrades (and beta updates, if you're in the beta programme).Peter_Rijs said:It is ridiculous that you cannot see from within the BricsCad application that an update/upgrade is available
0 -
I am happy that 90% of my other Pro Apps do offer Update hints and loading
from within the App. I wish Bricscad could do that too.
OK Blender for Mac updating is also (completely manually.
(While on Windows automatically from MS Store or on Linux Store, Snap or Flatpack too)
But as there are new Blender builds every single day,
I'm not that bothered not getting a notification.
And as I'm from Germany, I will get main releases notification a month
or so too late, once the german localization is ready - which I do not use.
At least we get Bricscad Beta notifications.0 -
Hi, I am new in Bricscad (was using Autodesk 205 years on Windows comp.) and also quite new with Mac..
Today I have downloaded BricsCAD-V25.1.07-1-en_US, installed it, licensed it, and got prompt that new version V25.1.07-01 is released. And it keep telling me that I should upgrade… Well if I open "About", there is only V25.1.07 shown ..
In previous, I had V24 and got info that can upgrade to V25.. Well, to my surprise it was whole new installation, next to V24.. so no update, no upgrade, but new installation.
Anywhere, neither asking BricsSYS, I got information, how to proceed (should I deactivate, uninstall old version, than install new, or should I keep old and install new .. No info.. Well, BricsCad is more favorable in pricing than Autodesk, but terrible start-up in case of support and interface ..
Can somebody help me what is the approach to upgrade? Would appreciate really in future.
0 -
Noticed that too from the beginning. Annoying.
0 -
Good day - Yes, It seems the software doesn't know what version is installed. If you enable the Menu Bar you can click on HELP and then click on ABOUT to see the current version. Sometimes I forget what version is installed and need to compare when an update is available. Thx
0 -
@Prem: New versions of Bricscad have been separate installs for as long as I've been using Bricscad. The first line of the latest release notes is, "BricsCAD® (Windows) V25 installs and runs independently of previous BricsCAD versions." It is OK to keep whatever older versions installed and they will still work, or you can remove them. You can have an instance of V24 running at the same time as an instance of V25 and they will not interfere wit each other.
One thing to be aware of is that importing an old profile can retain pointers to old versions in the CUI files. It is best to create a new profile for a new version rather than importing an old profile unless you are comfortable editing the new CUI file manually.
0 -
I'm surprised forum administrators haven't created a "sticky" here with latest Update Announcements / Release Notes.
1 -
CORRECTION - I apologise for mis typing - I have no excuse. I ment update NOT version. Yes the version is a completely different app. (I love the new logo-rounded corners anyone?)
For me it's not a big issue. I am sure Brics sys is aware of the situation and will correct it in due time.
0 -
Bricscad is not the only App that does this.
And no, it isn't a big problem, just a bad habit.From my experience, any App with auto update check works this way unfortunately.
If you have a new and a previous version installed, the previous version likely will never stop to inform you that there is a newer version available. Probably there is no way to check if that version is already installed or even running beside ;)But notifying about an available Update with the same version as already installed is another level.
0
