Hole Questions
1.) Is there a way to keep the last entered values I used when creating a hole?
( i.e. properties for a #10 thru hole?)
2.) can I just copy the holes throughout the design, sometimes when I do, they lose the translucent appearance they had after I copy them, is that ok?!?
3.) Is there a way to go thru (2) parts while keeping the top hole portion a CS thru-hole and the hole in the next part to be a threaded hole?
Sorry if this is easy, but I am switching from Fusion 360 as it is way too slow and I want to stay in the ".dwg" format...Thanks in Advance!
0
You can use BMLINK to update the connection between a component and solids. And you can use BMUNLINK to break the connection.
Regards,
Jason Bourhill
BricsCAD V23 Ultimate
CAD Concepts0 -
Thank you, slightly different than I am used to in Inventor and fusion 360.0
