** Error: Automation Error E_FAIL; [IAcadDocument] function [LAYERS] unspecified error**
Why am I getting this error?
I'm using the Cone11 traffic management operations software on BricsCad Lite, and whenever I try to place a sign on the modelspace I get this notification in the command console.
I have been saving and restarting Brics each time and it reopens and works perfectly (until I begin the next session that I open from my template.
Not sure how to go about remedying this; any help would be greatly appreciated!
Many thanks
Many thanks
0
Did you go back to Cone 11 for help that should be 1st step.0
I just wondered if anyone knew what type of error this might be. Naturally, upon contacting Cone they were not particularly helpful. Now I feel less helped than before.0
It may need Bricads Pro not Bricscad Lite. Ask them again.0
I would be inclined to agree with you except I've been using the Lite version for the past 8 months without this error, so I want to believe it's a change I've made in the settings or an issue I can easily address.0
It’s most likely the module, you can test to see if the LAYERS method is available to lite with a simple lisp routine.
(defun c:doit ()
(print(setq acadobject (vlax-get-Acad-Object)))
(print(setq activedocument (vla-get-activedocument acadobject)))
(print(setq LayerTable (vla-get-layers activedocument)))
(print(setq theLayer (vla-item LayerTable "0")))
(vla-put-activelayer activedocument (vla-item LayerTable "0"))
(print(setq aNewLayer (vla-add LayerTable "NewLayer")))
)0 -
Hi Nigel,
Thank you for the insight! Am I correct in thinking I simply import that into notepad, save it as a .LSP then drag + drop into BricsCad? What is this code supposed to do exactly? Sorry if I come across as dense, I'm still relatively new to this whole industry!
Many thanksNigelTufnel said:It’s most likely the module, you can test to see if the LAYERS method is available to lite with a simple lisp routine.
(defun c:doit ()
)0 -
yep, or copy and paste it onto the command line, and type doitSticksAndBrics said:Hi Nigel,
if you see something like
and if you have a new layer named "NewLayer" then IAcadDocument.LAYERS works and it's probably the module that's broken
VLA-OBJECT IAcadApplication 0000000042FC2190
VLA-OBJECT IAcadDocument 000000004BFF2798
VLA-OBJECT IAcadLayers 000000004382EE40
VLA-OBJECT IAcadLayer 000000004382EEC0
VLA-OBJECT IAcadLayer 000000004382EF40
0 -
I'll be honest in that I blindly followed your instructions, and can say that I have not found this issue to appear once in the last 3 days!! I think you've solved it, whatever the issue actually was. Thank you so much Nigel as you've saved me a great deal of stress
0
