Saving Custom Hatching For Predefined Access
Hi guys,
I'm looking to get it so that every time I open BricsCad, the default Hatching option is the one I use most regularly.
Typically, I use 'user Defined' to set it to how I like it (ANS131 with a red/cyan cross-hatch with 0.5 spacing), how might I go about saving these settings as a pre-defined option that appears as default whenever the app is launched? Could someone explain it step by step for me, as a newbie that may get lost with some of the lingo.
Much appreciated and many thanks in advance.
0
If you do Setvar ? * you will see all the setvar values and yes lots of them ok the hint look at HP vars.
HPANG 0.000
HPANNOTATIVE 0
HPASSOC 0
HPBACKGROUNDCOLOR "NONE"
HPBOUND 1
HPBOUNDRETAIN 0
HPCOLOR "."
HPDOUBLE 0
HPDRAWORDER 3
HPGAPTOL 0.500
HPISLANDDETECTION 0
HPLAYER "."
HPLINETYPE 0
HPMAXAREAS 0
HPNAME ""
HPOBJWARNING 10000
HPORIGIN X= 0.000 Y= 0.000 Z= 0.000
HPSCALE 1.000
HPSEPARATE 0
HPSPACE 1.000
HPTRANSPARENCY "."
You can do hpname or in a lisp (setvar 'hpname "Ansi31") you can do this in a "Appload" lisp file that has your setvars in it like Osnaps etc but that is Osmode. I will let you work out the 0.5 which variable from above.
Use "-hatch" and the predefined should be set correct and no dialouge.
If you dont know about autoload lisp on start up come back.0 -
You can also create Hatch tools with desired options on Tool palette, and use them when necessary instead of Hatch command: https://help.bricsys.com/document/_guides--BCAD_customization--GD_workingwithtoolpalettes/V23/EN_US?id=1650791437570
These are both very helpful answers, thank you for your thorough responses!0
