Civil Points - Export to CSV files
Are you able to export Civil Points to a CSV file ?
Cheers Jason
Currently you can use the DATAEXTRACTION command for this. Select points in the drawing, then in the list of available properties find and choose Point number, Point raw description (if you need it), Easting, Northing and Elevation. The output file will include also Count and Name columns, which could be deleted e.g. via Excel.0
Thanks ! Would be great to have the same interface as the civil point import function0
Should be able to get the entity properties of the civil point, I do stuff with CIV3D have not played with Bricscad civil points, try this and post result.
(entget (car (entsel "pick cogo point ")))0 -
hi where is the "point number, point raw……., etc"?
thanks
0 -
Hi @Zed , there are no Civil point entities on your example. When they are present in the drawing and selected for data extraction, specific properties become availiable.
0 -
From your screen grabs, you look to be using BricsCAD Lite. You need BricsCAD Professional or greater to work with BricsCAD Civilpoints.
Starting with BricsCAD 25 Professional you now have the option to easily export Civilpoints from a drawing by right clicking on the applicable point group from the Civil Explorer Panel and selecting Export points…
If you want to use DATAEXTRACTION, then this forum post includes an example based around Civilpoints.
I assume that this would work in BricsCAD Lite.
Jason Bourhill
CAD Concepts Ltd
1
