I need Ctrl C to be CANCEL
How can I set my Ctrl C setting to become a CANCEL command instead of the default Copy-Clip? AutoCAD used a "ClassicKeys" setting to do this. But there is not setting such as this in Bricscad. Any help would be appreciated.
0
Type CUI to bring up the CUI editor. In the keyboard tab find the Ctrl-C entry and change it as you see fit.0
The ESC key cancels any active command or grip-stretch and de-selects all.0
changing Ctrl+C in CUI to anything else doesn't allow me to cancel any current command. For example, when I'm in the line command, and I attempt to change ctrl c to 'Cancel' it does nothing. If I just leave the ^c^c it does nothing. I even attempted to put ESC there and that didn't work either. Running out of ideas....
I don't want to have to use the ESC key because I need to move my hand up to that button to select it. Keeping my hands stationary really helps my productivitity. Plus my use of ctrl c for cancel has been going on for 30 years and I wish to keep using that command.0 -
I'm surprised thatJohn6373 said:changing Ctrl+C in CUI to anything else doesn't allow me to cancel any current command. For example, when I'm in the line command, and I attempt to change ctrl c to 'Cancel' it does nothing. If I just leave the ^c^c it does nothing. I even attempted to put ESC there and that didn't work either. Running out of ideas....
^c^cdoesn't work. In my older version of Bricscad, it does work. I re-definedCtrl+Cto just^c, and now it cancels the running command.
I don't know why the new version should be different. The online help page for Keyboard Shortcuts says thatCtrl+[andCtrl+\both cancel the running command. How are they defined in the Tools>Customize>Keyboard dialog in your version? In my older version, they're defined as just^c.
The only other thing I can think of is that if there's more than one definition ofCtrl+C, then the last one is used, and any earlier ones are ignored.
Note that in my version^conly cancels the running command. It doesn't de-select all. I don't know whether you want that. But I find that if I change the definition to^c(sssetfirst)(nil)(nil), then it also de-selects all.
0 -
I use AutoHotKey to remap keys. It can be setup to where it’s app dependent
https://www.autohotkey.com/
0
