Purge with 'nested items' option?
Hi all,
I was wondering. Is there a way to purge nested items when purging? Now I have to do it manually several times. I thought I once read that BricsCAD was able to do this, but I'm not sure.
Thanks for thinking with me!
0
I've never tried it, but the online help page for the -PURGE command says that if you use the BA option it will purge nested entities.0
Thanks! I'll try that one. The Dialog page of the PURGE command took me to this page: https://help.bricsys.com/document/_dialogboxes--DB_purge/V24/EN_US?id=165727492810
There I didn't find it. But using -PURGE instead of PURGE in the command line gives more options than the dialog box. I'll consider making a feature request for some more options from the command placed in the dialog box.
Thanks again!0 -
Yes, currently there is no option for nested purge in PURGE dialog, this could be done via command line only, as
Anthony suggested. It's a good idea to send a feature request about it to add a voice to other requests of this option.0
