v24 Teething problems....
Having had to wait for Cloudworx to support v24, I have only today installed BricsCAD Pro v24.
Right off the bat, I like to have my panels (Properties, Layers etc.) on the left side and then on the right I have snaps and zoom toolbars.
I've used BricsCAD since v21 and this is the first version I just can't move any of these to where I want them.
I can't move the main bar with Properties etc that is on the right by default.
I have opened snaps which has docked at the top and I can't move it.
I have opened zoom which is just floating in space but i can't move that either.
I am going to assume there's a lock toolbars setting or something which when that is the case is like super simple to find....until now.
......help!
......help!
0
...right holding ctrl and dragging has moved them but they won't dock anywhere now. Why was this so simple I have never had to give it a blind bit of thought before and now someone has decided to make it really annoying, who was this person....why did they do this!?0
My v23 seems to be behaving the same now...what is going on!0
I have never heard of nor used "LOCKUI" but somehow installing v24 enabled this on it and v23 when it wasn't before !?
I have now reset to "0" and it behaves as it should again FFS.0 -
LOCKUI came some versions before V24 already (V21 ?)
I am a notorious button/Icon clicker,
so for me switching means the most right button in the status bar.
Usually I have LOCKUI enabled. I only switch it off when
I rearrange Palettes, which I do not do that often.0
