Command reference on help.Bricsys.com
Hi,
We upgraded from BricsCAD Pro to BricsCAD Mechanical this year. Now i wanted to check the command reference list https://help.bricsys.com/en-us/document/command-reference?version=V22&id=165079036112 to check which am* commands are available that can be useful for us. Unfortunately i could only find AMSURFSYM and AMWELDSYM in the list. When i search on the help page there are a lot more AM* commands.
Does anyone now a good ressource for all commands that are available in BricsCAD Mechanical and not in BricsCAD Pro?
Obviously I am asking for a simple solution if there isn't one I will work with the search on the help page.
Kind regards
Michael
Kind regards
Michael
0
Hello Michael,
If you have upgraded this year, I imagine that you are using BricsCAD Mechanical v24, correct?
If that is the case, please take a look at the command reference for v24 at the link below:
https://help.bricsys.com/en-us/document/command-reference?version=V24&id=165079036112
All the best,
Billie0 -
Hi Billie,
Thank you. We changed to V23 but I saw the version reference in the link and was able to open the correct command reference.
kind regards
Michael0
