T Connect + L Connect non functional?
Hi all, I've recently learned that a command exists that automatically connects two polyline edges (TConnect + LConnect) from the Bricsy site, yet cannot seem to get it to work...
It doesn't appear when typed into the command bar, yet does appear under 3D Modelling - I set up a shortcut (Ctrl+L) to test the two commands (they both appear in the populated list within keyboard shortcuts under Customize) but when I then did the shortcut, Bricscad didn't recognise it as an entry (please see attachment)
This has kinda stumped me to be honest.
If anyone could offer some solutions I would be massively appreciative.
Many thanks
0
What level of Bricscad do you have? LConnect and TConnect require Pro or higher according to the online documentation at https://help.bricsys.com. If may also depend on the version. I have LConnect, TConnect, and Connect available in V24 Pro.0
I think these commands are 3D only.
https://help.bricsys.com/en-us/document/command-reference/l/lconnect-command?version=V24&id=165079085354
I know them from Bricscad BIM.
But I am sure there are ways to connect 2D Shapes ....0 -
Just to clarify, I never did find a reason why I have no Connect command on my bricscad...0
Hello,
Indeed, the _lconnect and _tconnect commands are not available in BricsCAD Lite or Shape version.
https://help.bricsys.com/en-us/document/command-reference/t/tconnect-command?version=V24&id=165079112140
If you want these commands, you need to have BricsCAD Pro/Mechanical/BIM.0 -
That's so strange that I can set it as a shortcut but then not use it within the application I set up the shortcut in lol.
Thanks for your help, if we know of any lisp workarounds etc I'd love to hear ideas x0 -
The CONNECT command was introduced for BricsCAD V23. It works only on 2D entities.
https://help.bricsys.com/document/command-reference/c/connect-command?version=V24&id=166028704710
The LCONNECT and TCONNECT commands have been in the program longer and work only on 3D entities.
https://help.bricsys.com/document/command-reference/t/tconnect-command?version=V24&id=165079112140
https://help.bricsys.com/document/command-reference/l/lconnect-command?version=V24&id=1650790853540
