Cloudworx not working with BricsCAD Pro - 24.2.04
Error loading "C:\Program Files\Leica Geosystems\CloudWorx for BricsCAD\V24\CloudWorx.arx": .
DemandLoad failed due to dependencies problems!
Application : CloudWorx
I have contacted Leica HDS support also but that plugin hasn't been updated, only Bricscad.
what version are you upgrading from?0
24.2.03 I believe. So not jumping a version, I was already on v24. I've got Leica support baffled, they are updating their BricsCAD to 24.02.04 to see if it breaks theirs too. We reinstalled Cloudworx and now nothing of it shows in BricsCAD at all, no menus, no ribbon and no CUI for it despite showing as installed.
My money is on BricsCAD update has broken Cloudworx.0 -
Confirmed, the latest version of BricsCAD v24 breaks the current version of Cloudworx. Leica have tested and as soon as you go to version 24.2.04 it totally breaks Cloudworx, you will not be able to use it. this has been escalated but being as both companies are Hexagon, hopefully the Bricsys team will read this too.1
Hello,
I just upgraded to BricsCAD Pro version 24.2.06 and installed Leica_CloudWorx_For_BricsCAD_2023.1.0_PGR_13122023.exe as suggested by Leica Tech. but I'm getting the same error.
Description : CloudWorx
Module Path : C:\Program Files\Leica Geosystems\CloudWorx for BricsCAD\V24\CloudWorx.arx0 -
hi,
there was a dll problem in that Cloudworx version but that should be resolved in Leica Cloudworx 2024.1.0 I believe.
0 -
Hi Plet,
Thanks for the reply. I found and installed Leica Cloudworx 2024.1.0 I as you have suggested. It must have just been release or I somehow missed it when looking for the latest version.
Everything seems to be working now!
Thanks!
0 -
ALl in time for v25 so it will probably break again on that!
0 -
Hi. Any update on this? I'm still only able to use Bricscad pro V23.1.05 with Cloudworx..
0 -
It works fine with 24 but the question has now moved to whether or not it works with v25!
0 -
Hello, This is an issue on the cloudworx's side as it is a plugin on top of BricsCAD. You should contact their customer service about this.
0 -
Whilst true, one would think that both being part of Hexagon, you might want to make a bit more effort than with the other plugins to ensure your ecosystem worked. Call me old fashioned.
0 -
Hi,
I checked with the Leica Cloudworx team and this is planned for 25Q1. We are working to streamline our roadmaps to have the releases closer to each other.
0
