attipedit
Hello,
Our firm recently moved from AutoCAD to BricsCAD, I noticed if I wanna edit an attribute the attipedit command isnt bound to CTRL + Double click. Is there any chance we could bound that command to these binds? Like in AutoCAD.
Cheers,
Martin
Hi Martin,
You are right, Attipedit command is not run by CTRL + Double click in BricsCAD. We have a feature request task to add this feature, you can add value to the task creating a feature request about it.
But we have another quick way to edit attribute value - via Rollover tips. Choose 'Value' for Attribute entity via Customize dialog: (run CUI command -> Properties tab -> Entity -> Text -> Attribute. After that, when you hover the attribute in block insert and press Ctrl to highlight it - there is an editable 'Value' field in Rollover tips.
0
