Keep only "Blocks" in current selection.
Hi all, and thanks for reading in advance
Short: When I have a selection with all kinds of objects (Blocks, lines, dimensions, etc…).
I'ld like a command that keeps only the blocks in my selection.
Long: I need to do this so the attributes of my blocks become visible. So I can fill in values.
In Autocad I had a working lisp for this (see attached).
Or with autocad's "Quick Select" this was also possible.
