BIM Section Blocks Placed Next to Each Other
Good morning,
For some time now, I have been experiencing this issue when creating print layouts for models created with BricsCAD BIM. After creating the sections with BimSectionUpdate, I find that the generated blocks are placed next to each other: is there a way to space them apart?
0
hi Davide,
the setting BIM/ 'Section result interval' sets the distance between the boundingboxes of the section resultblocks.
1 -
Thank you,
I would have never figured it out. I was looking in the sheetset options. Why did they set it to 0? Strange.
0 -
That is indeed strange, default should be 10meter. In my install it is.
0
