Relative paths errors fixed by LISP?
So if I have a DWG on C:\PROJECTS\CLIENT and then I add a couple PDFS. One from C:\PROJECTS\CLIENT\PDFS and another from our cloud P:\PROJECTS\CLIENT\PDFS, it will complain that it can't make the 2nd addition as a RELATIVE PATH. How illogical is that?
Anyhow. I manage via a LISP function to change the path to relative. Anything worry about in that manner? Bricscad v20 btw, but it shows the PDF just fine. Says it is found on P: drive and the other found on C: … seems to work, and maybe I don't understand why the software would put up that blocking of different drive letters being able to do relative paths
Hello.
Relative paths only make sense for files located on the same drive (same letter) as the main file.
This feature is useful for cases when a certain folder structure is moved to another location.For files located on a drive other the main file, the path can only be absolute, as it is saved inside the main drawing as a full path, starting with the drive letter.
This happened also in your testing, the path was saved as starting with P:.
This is, in fact, an absolute path, even if you managed to use lisp and set it as relative.A safer way of working seems to be to let it as absolute, as it really is.
1
