Text formatting dialog box - disabling. UCS Icon - lock in place.
Hi All
I've been working towards making the final switch from AutoCAD to BricsCAD. I've managed to get it looking and behaving largely how I like to work, but a few little annoying things remain.
One of them is the (what I find extremely annoying) Text Formatting dialog box popping up every time I move from a table cell to another one. In AC it's a clean quick process. Use the Tab key to jump to the next cell and just quickly keep editing. In BC I find the Text formatting box disappearing and re-appearing as I move cell to cell becomes very distracting. Is there a way to disable it?
The second problem I have; Is there a way to permanently lock the UCS icon into the lower left corner? I've tried all the variables but it will still move all over the place when I use the mouse wheel to zoom in and out. In AC it can be locked in place by unticking the "Display at UCS origin point" setting. I can't find the equivalent in BC. Is there one?
TIA for any help. Cheers.
Ucsicon C ??
0 -
UCSICONPOS is integer only, 0 to 3. I'm on 1. But it will move from the lower left all the time depending on zooming action. I want it to be stuck fast in the lower left corner.
0 -
Sorry Alan, you were right! I used the UCSICON command instead and found that C option. That's one headache solved. Thank you very much.
1
