lisp, des and bricscad
please someone take a look at this thread
https://www.theswamp.org/index.php?topic=59747.0
  • If you've found a deficiency in .DES encryption, then it would be best to raise a support request with Bricsys.
    Raise a support request on LISP.
    You will be able to talk to them more plainly on the issue you've found and hopefully get it fixed.
  • I did a bit of searching and found this. https://www.codeconvert.ai/lisp-to-csharp-converter
    I would appreciate if some one could see if its useable, I dont program in C.
    ; goes through all layout tabs and zooms all
    ; By Alan H june 2011
    (defun c:zall ( / d curtab)
    (vl-load-com)
    (command "_.pspace")
    (setq curtab (getvar "Ctab"))
    (setq this_dwg (vlax-get-acad-object))
    (foreach d (layoutlist)
    (setvar "CTAB" d)
    (COMMAND "pSPACE")
    (command "zoom" "C" "400,277" 750) ; in case junk around title block
    (setvar "ctab" curtab)
    (princ)
    Code produced.
    using Autodesk.AutoCAD.ApplicationServices;
    using Autodesk.AutoCAD.DatabaseServices;
    using Autodesk.AutoCAD.Runtime;
    using Autodesk.AutoCAD.EditorInput;
    public class ZoomAllLayouts
    [CommandMethod("ZALL")]
    public void ZoomAll()
    Document doc = Application.DocumentManager.MdiActiveDocument;
    Editor ed = doc.Editor;
        // Switch to model space
        ed.Command("_.pspace");
        // Store the current tab
        string currentTab = (string)doc.Database.GetVariable("CTAB");
        // Get the layout manager
        LayoutManager layoutManager = LayoutManager.Current;
        // Get the layout names
        foreach (string layoutName in layoutManager.GetLayoutNames())
            // Set the current layout
            layoutManager.CurrentLayout = layoutName;
            // Switch to paper space
            // Zoom to specified area
            ed.Command("zoom", "C", "400,277", 750);
        // Restore the original tab
        layoutManager.CurrentLayout = currentTab;
  • encrypting a Lisp file for Bricscad,
    and "converting" this file to C#
    are TWO SEPARATE TOPICS...
    and the second one
    (even though it's an interesting thing)
    is not
    the solution to the first one ...
  • ALANH
    edited September 9
    I don't understand why the response yes it has been disclosed that des is not maybe secure, but higher level languages like C# are more secure so it may be a way of securing the code you have invested your time and effort into.
    The convert to C is offered as an alternative to making des files. I don't use Visual Studio so don't know next step.
    This is what you hinted at Post 37 over at Theswamp.
    • the software to convert (CodeConvert) Lisp to C#,
      offers many other types of conversion from many languages ​​to many other languages
    • the procedure seems to be based on artificial intelligence
    • I suggest you download a large and fairly complex lisp file, translate it into C# with CodeConvert, compile it, load it into Acad, and thoroughly test the behavior of the software
    • if all goes well, we can say that codeConvert offers us a real alternative to encrypting Lisp files in Fas or Des format
    • anyway all this is interesting, but this does not mean that it is not better for ACAD and BCAD to encrypt Lisp files obtaining a non-vulnerable result
    download :
    https://www.theswamp.org/index.php?action=dlattach;topic=9042.0;attach=43221
    and do the tests I told you and then let us know
  • https://www.theswamp.org/index.php?topic=59747.45
    … the latest news !
