Hyperlinks
If I email a dwg with a hyperlink to an image. how do I make sure the hyperlink updates to the new location on the receivers computer? is there a way to set it so I just zip the dwg up with the image it will reference the folder that the image is in once saved onto another computer? Also when i plot to PDF can this ability be kept also where the hyperlink updates?
Thanks
1
If the image is in the same directory as the dwg it may work. Most times if say a xref is not where the link shows then CAD will look again at where the dwg is located.
1 -
Hi Alan,
I have tried etransmit but that doesnt work either. I have tested it out internally in the office and unfortunately it keeps the whole file location for the image.
0
