Need help Toolbar problem
Hello!
I accidentally did something silly and completely lost my toolbar. I received a tip to go back to default settings, which was supposed to solve the issue. I did that, and sure, everything else came back, but not the MagiCad tabs.
Do you know how I can get them back? I've been banging my head against the wall and can't figure out what to do. I've tried reinstalling everything, but it still doesn't work. I can see that MagiCad starts when I open a model, but none of the tabs appear in the toolbar.
That looks like a ribbon not Toolbar. You could see if you have a Magicad.CUI and use menuload.
Yes have screwed up the menu's at times and can be a pain to get back finding various CUI etc.
I would suggest when getting it to work save a profile and we set user named Workspaces. So did not edit the defaults.
1 -
Thank you! It worked!
0
![2024-10-10 11_08_29-BricsCAD Pro - [V57-P-11.dwg].png](https://forum.bricsys.com/uploads/A9HCCL1NLOVG/2024-10-10-11-08-29-bricscad-pro-5bv57-p-11-dwg-5d.png)
