V25 Trim command
Is there a way to change the TRIM command to Standard mode other than within the command, or to set TRIM so that Standard mode is used when the command is called in LISP? The new Quick mode breaks several of my lisp routines.
0
Would you be looking for the "TrimExtendMode" system variable?
0 -
Thanks.
0 -
Your welcome 🙂
0
