Hi,
could you describe the workflow where you would need this feature.
Please create a support request to add more weight to it.
https://boa.bricsys.com/boa/supportrequest/NewSupportRequest.do
link any property value to drawing's/setting's variables/constants
Hi,
1 -
This is a normal feature in FREECAD
in the minute 29:58 the drawer is linking a table cell value to a property value with a string, very similar to REVIT
in BricsCAD something similar is possible with DIMENSIONS and parametric properties.
I never received answer when I try to open a request a feature, is more probable get an answer to the forum to use a script lisp.0 -
Dynamic components similar to SKETCHUP
1 -
Yes, have many names, but is possible to do this in BricsCAD? maybe with reactors?
0 -
I hope there are similar examples for making decorative components.
1
