Some Errors
edited November 2024 in Linux
Hello everyone
New BC user here, currently evaluating it with the trial version and liking what I'm seeing so far.
I have been experiencing some errors though and before I submit another support request I thought I'd ask here first in case it's an easy fix that people know about.
The image below is one of a few similar errors that I experience. I have applied some materials to some objects and I get this error when I open the drawing.
I'm using BC v25 and Ubuntu 24.02 LTS.
Regards
Charlie
Welcome!
It looks like you're new here. Sign in or register to get started.
  • Hello Charles,
    Close all instances of BricsCAD then type the following in the terminal:
    sudo chmod 777 /var/bricsys/RenderMaterials
  • I wouldn't do that unless you know it makes sense
  • Problem solved, muchisimo gracias.
Welcome!
Welcome!
