Convert lsp to fas
Hello.
Fas files cannot be created in Bricscad.
However, there is another solution to encrypt lisp files - DEScoder.
DEScoder creates encrypted lisp files with the extension .des
These .des files can be used only in Bricscad.The next link points to a page containing more information on this topic.
0 -
You can via lisp compile multiple lsp files in one go to individual compiled files. Either FAS or DES depending on which software you are using.
Acad example
; must have vlide open to work
(vla-sendcommand (vla-get-activedocument (vlax-get-acad-object)) "Vlide")
(setq loads (list
" 3d pts on face 4"lots of lsp file names
(setq loc1 "C:\\lisp-CAD-TOOLS\") ;;change dirs to where ever you want them found
(setq loc2 "D:\\lisp-\\compile\\") ;;change dirs to where ever you want them saved
(foreach lisp loads
(vlisp-compile 'st (strcat loc1 lisp ".lsp") (strcat loc2 lisp ".fas"))
)Another 1 file
(defun comp ( )
(if (null vlisp-compile) (c:vlide T))
(setq fname (getfiled "Pick lisp to be compiled" "" "lsp" 8))
(setq len (strlen fname))
(setq diff (- len (+ 15 3)))
(setq fnameout (substr fname 15 diff))
(vlisp-compile 'st fname (strcat "d:\\compiled\" fnameout ".fas"))
(comp)Now where did I put my des version.
0 -
https://www.theswamp.org/index.php?topic=59747.0
0
