Reverse Direction of a Polyline
Hello, I m new here, so Hi to everyone.
I ve installed BricsCAD some days now and I can say I m really happy.
I was using Acad. I need to reverse the direction of a polyline with one command, just how Im used to do. I don't remember the command I was using because I customize a lot (it was just the "R" command… I think it was the REVERSE Acad)
Now in BricsCAD I have to PEDIT and then press R to reverse the polyline
Is there a way to do it in one step? One command solution?
Thanks a lot
Hello.
In Bricscad, the REVERSE command is not defined.
The simpleset way of working seems to be to create a button tool using an expression like:
^C^C_.pedit;_r;;A more advanced solution would be to create a lisp function defining a custom command named REVERSE and have this function automatically loaded.
1 -
see attached lisp.
PEDIT command have reverse function.
using lisp save some clicks…
1 -
Thanks to all of you. It is very helpfull. Nice forum!
0 -
This is what I use to work out the start end point of a P/Line.
(defun swapends (entl / )
(setq pt (cadr entl))
(setq obj (vlax-ename->vla-object (car entl)))
(setq start (vlax-curve-getstartPoint obj))
(setq end (vlax-curve-getendPoint obj))
(setq d1 (distance pt start))
(setq d2 (distance pt end))
(if (> d1 d2)
(progn
(if (= (vlax-get obj 'objectname) "LWPOLYLINE")
(command "pedit" (car entl) "reverse" "")
(progn
(vlax-put obj 'startpoint end)
(vlax-put obj 'endpoint start)
(princ)
)(setq ent (entsel "\nPick object near end "))
(swapends ent)0
