Attributes not being moved by parametric move / stretch
Hallo I applied a parametric move and stretch to a text attribute and I always have to update the view using attsync. Is there a way to apply move to the attribute without having to attsync all the time ?
thanks
Luca
Hello.
There is an issue with moving and stretching attributes.
This is currently under investigation.
So, for now, a synchronization is needed to have the attributes in the right position after adjusting the block.1 -
thanks noted - can you revert once this is solved?
Regards
Luca
0 -
Any update on this?
2 -
I have a similar problem.
Neither moving nor stretching works
0 -
Any update on this? Still not able to move attribute with Stretch operation.
1 -
@BricsCADSupport - What's the status of this? How high of priority is at time? Thanks
0 -
Anyone who as commented already, did you "up vote" the original post? And it might help if you had coworkers, and friends up vote.
1 -
Did you check the Release notes for V26? It's mentioned there: "Fixed an issue that caused attribute positions to not update when the related parametric operation was modified."
Also new ATTFULLUPDATE variable is implemented:
"With the default value set to 1, attributes are moved along with block references when modified using the Stretch action".
0
