Crash when I try to make an array with parametric text
I am trying to make a parametric block where I can set the number of rows in the contained array as a parameter. Each row needs to have parametric text as a description. The idea is to make PLC card creation easier within my drawings because they all have different quantities and terminal tags across manufacturers.
As soon as I try to make an array containing parametric text, Bricscad has a fatal error and crashes as soon as I click "rectangular" during the array creation. Why is this?
