using CTRL+F inside xref'd drawings
Is there any way to use the search function in a drawing that has multiple xref's in it?
The reason I ask is that we have a project at hand where we need to have a whole bunch of drawings by means of xref added to it. All the sub-drawings(=xref) are still work in progress and actively modified. It would be very beneficial if the overview drawing could be searched (tags) without having to constantly opening up all the sub-drawings to try to find the one tag in the one drawing.
I would think that either I'm overlooking something or that at least someone has a LISP routine that does that but so far I haven't found any solution.
Any suggestions would be greatly appreciated.
Kind regards
Peter
