create 2D-polyline trough points with one command
  • hello!
    is there a possibility to create a 2D-polyline trough points with one command?
    with fitpoly i can only create a statistical mean value between the points
    This is just an example, in many cases the poly should be set by 100 points or more…
    thanks f. helping
  • Its_Alive
    edited March 2025
    Unordered points is NP-Hard, so you would need to use a solver. Python’s networkx has one that’s easy to use, but a tad slow. Takes about a half second to compute 100 nodes
    Google has an extremely fast solver but it’s a bit harder to use
    https://developers.google.com/optimization/routing/tsp
    here’s a sample from a CAD perspective
    https://www.theswamp.org/index.php?topic=58634
    import traceback
    from pyrx import Ap, Db, Ge, Ed
    import networkx as nx
    @Ap.Command("doit")
    def make_pline_from_unordered_points():
        try:
            db = Db.curDb()
            ps, ss = Ed.Editor.select([(0, "POINT")])
            if ps != Ed.PromptStatus.eOk:
                raise RuntimeError("Selection Error! {}: ".format(ps))
            graph = nx.Graph()
            positions = [Db.Point(id).position() for id in ss.objectIds()]
            for i in positions:
                for j in positions:
                    if i == j:
                        continue
                    graph.add_edge(i, j, weight=i.distanceTo(j))
            tsp = list(nx.approximation.traveling_salesman_problem(graph,cycle=False))
            pl = Db.Polyline(tsp)
            plid = db.addToCurrentspace(pl)
        except Exception as err:
            traceback.print_exception(err)
  • If they are in a XY pattern then can get all the points and just do that sort on X & Y then make a pline. Should be instant.
    (defun c:plpts ( / pts ss x)
    (defun AHpllst ( lst / x)
    (command "_pline")
    (while (= (getvar "cmdactive") 1 )
    (repeat (setq x (length lst))
    (command (nth (setq x (- x 1)) lst))
    (command "")
    (setq ss (ssget '((0 . "POINT"))))
    ; sorts on 1st two items
    (setq pts
    (vl-sort pts
    '(lambda (a b)
    (cond
    ((< (car a) (car b)))
    ((= (car a) (car b))
    (< (cadr a) (cadr b)))
    (princ)
    I can see this failing depending on how points are laid out.
  • Its_Alive
    edited March 2025
    Yeah, just sorting will work some of the time, it gets harder with C or S shapes, TSP solvers aren't perfect either, it’s only an approximation, exact can take years lol
    Here’s a wiki on the topic
    https://en.wikipedia.org/wiki/Travelling_salesman_problem#Computing_a_solution
    Google’s is the best; its what maps uses. Also, you can add constraints, like for circuit board design. Here’s the link for PyRx
    https://pypi.org/project/cad-pyrx/
  • Thanks for the suggestions.
    I think it wouldn't be too difficult for Bricsys to extend the fitpoly command. With fitpoly, I also need to semi-automatically define the point direction. Then, the resulting polyline (or spline) would only need to pass through the points.
  • Yes but in what order?
  • @petercad I think I know what you want. Just a quick hack below (wh
    ich takes always more trouble than expected) , it eats POINT entities and generates a 3DPoly, it works 3D.
    You can use it 2D too and if you want a polyline as output, you can comment and un comment the section at the end by starting lines with or without semicolons.
    After selecting a set of points, and a start point, distances are calculated and the closest point is the second vertex of the polyline. Same procedure from second point for remaining points and so on and so on.
    So drag file pts-3dpl.lsp in your drawing and test by using command pts-3dpl.
