Using FIELDS to automatically update a page number/name
Hi, is there a way to get the page name from the drawing updated automatically in a field?
These are the little tabs that usually have a viewport etc, I want each of their labels somewhere on the plans, and ideally have the field be able to populate automatically
We currently use one for the title block, which is taken straight from the filename. It works brilliantly.
But for some reason I can't find a way to make this work, even though it almost feels like it should be simpler.
I welcome any advise that can be offered here.
Many thanks
do you mean like this?
BTW, i use dwgprops for all the job info fields
1 -
Thanks for the quick reply. Here are the names for a number of different phases that are on one job.
I tried using Diesel Expression, and it resulted in 4 dashes, which may be it trying to reference something that I've not included… I'm not sure how I would do that though. I did try hitting Update Field to no effect.
Many thanks
0 -
I'm so sorry, I didnt' see your red underlined expression text - this is now working perfectly and I honestly can't thank you enough!!! :) Have a great day
Thread can be closed
1 -
Just a comment if you want "page X of Y" can also be done as fields, the total number of layouts and the current layout number is ".Taborder", it did not work in V24, I am not sure about latest version V25xxx. .Tabcount I think worked.
1
