Floor elevation
Hi,
I am a bit into Python, testing some small scripts for BricsCAD.
Any ideas how to get Floor elevation? I want to use it to automatically get Window sill height.
0
You need to explain more about what makes a window are you using BIM, is it a block and so on.
0 -
OK.
It´s standard default BIM Window in BricsCAD BIM. In the Properties panel there is the Sill height. But it is "0mm" by default even if the window has no-zero sill height and has to be written manually. I would like the script to set it automatically.
Something like this:
SillHeight = Geometry/PositionZ - Window/Floor elevation
1
