Version 25.2.03-1 Selecting cuTting edges mode in TRIM causes crash
Curious if i'm the only one here:
When selecting the TRIM command and then entering T to select cutting edges makes the software crash instantly :-(
Been working two days with this version, but I'm going back to a previous version. This one has too many errors for me for a 'stable' release.
Please Bricsys, do your homework and don't release a version that contains this kinds of errors (as mentioned before in another post the Layer Control in the ribbon has a bug).
Small edit: just filed the bug and found as a small workaround for now the TRIMEXTENDMODE and set the value to STANDARD
You are not the only one) The same was reported for Beta, and development task has been created, as I know.
0 -
Any solutions as it crashes everytime use trim or extend :-(
0 -
Download the latest version 25.2.04-1 which was released last week. The issue is fixed in that release and trim and extend work normal.
0
