Redefining ctrl-middle mouse button
If I disable the default mouse shortcuts using CTRLMOUSE set to 0, then can I redefine these shortcuts?
I would like to use ctrl-middle button (and maybe shift-middle button) to enact realtime zoom (similar to what ctrl-shift-left button does when CTRLMOUSE = 1). I would like to be able to use this realtime zoom in the middle of a command, without having to "exit" from it as one does when using the RTZOOM command.
