draworder not work
in 2D Drafting
Hi, everyone! Please, can you help? Draw order not work in layout.
Change draw order [Above/Under/Clear all orders/bring to Front/send to Back] <send to Back>: F
DRAWORDER<br>Select entities to change draw order [selection options (?)]:
Entities in set: 1Change draw order [Above/Under/Clear all orders/bring to Front/send to Back] <send to Back>: F
Yelow is in layout, it can be in front.
0
Yellow is on layout, it can't be in front.
0 -
I do not understand clearly what you want,but in a layout you cannot send anything under a Viewport, any entity that is created in the Paper Space will always be placed on top of the viewport.0
Can you post the .DWG file?0
Try to turn Off option "Plot paperspace last" in Print or Page setup dialog - paper space entities will be printed first, then model space entities.
1 -
Lyubov Osina said:Try to turn Off option "Plot paperspace last" in Print or Page setup dialog - paper space entities will be printed first, then model space entities.
WOW, thank you Lyubov, never thought about this option!0 -
You are welcome, @fs_at12
0 -
Hi, but don't work. I am sending dwg file. Layout "sit" is ok, but layout "UZD" is not. Yellow circle is on layot but entities from model are visible.Anthony Apostolaros said:Can you post the .DWG file?
0 -
Each Layout has its own page setup. You checked "Plot paperspace last" for sit, but not for UZD.
You can copy the page setup from one Layout to another, in the Page Setups section of the Drawing Explorer.
1 -
@ Thank you very much. Yey, I change it in page setup. :-)Anthony Apostolaros said:Each Layout has its own page setup. You checked "Plot paperspace last" for sit, but not for UZD.
0
