Add command to Context Menu
in 2D Drafting
How can command be added to context menu, when it's a custom one.
I have already loaded a LISP file via APPLOAD.
Not sure if the LISP routine works in BricsCAD but will deal with that next (it works in AutoCAD).
I figured out how to add standard commands to context menu:
Type CUSTOMIZE or CUI. In Menu tab, go to Context menus. Right click, Insert item, select Create new tool for example, fill in details.
0
Yes, that's how you add a custom command to a context menu. Are you clear on the different types of context menus, e.g. Command, Default, and Edit?
If you post a lisp function here, people (not me) can tell you what needs to be changed, if anything.
1 -
Thanks Anthony, it's Default or Edit, but this is a custom command, not one already in there, so how do I create the command to shown in context menu.The Lisp is create a block in place:(defun c:Create_block_in_place (/ bkn eee i ndx nm ssst st)
(if (and (setq ssst (ssget)) (setq st (getpoint "\nPick Base Point: ")))
(progn (setq ndx 0)
(setq time (rtos (getvar "CDATE") 2 6)) ; Format YYYYMMDD.HHMMSS
(setq year (substr time 3 2)) ; Two digits instead of four
(setq month (substr time 5 2))
(setq day (substr time 7 2))
(setq hour (substr time 10 2)) ; Increment of 3 from day to account for "." character
(setq minutes (substr time 12 2))
(setq seconds (substr time 14 2))
(while (tblobjname "block" (setq nm (strcat "Block-" year month day hour minutes seconds))))
(entmake (list '(0 . "BLOCK")
'(100 . "AcDbEntity")
'(67 . 0)
'(8 . "0")
'(100 . "AcDbBlockReference")
(cons 2 nm)
(cons 10 st)
'(70 . 0)
(repeat (sslength ssst)
(entmake (cdr (entget (ssname ssst ndx))))
(entdel (ssname ssst ndx))
(setq ndx (+ 1 ndx))
(entmake '((0 . "ENDBLK") (100 . "AcDbBlockEnd") (8 . "0")))
(entmake (list (cons 0 "INSERT")
(cons 2 nm)
(cons 6 (getvar "CELTYPE"))
(cons 8 (getvar "CLAYER"))
(cons 66 0)
(cons 10 st)
(cons 41 1)
(cons 42 1)
(cons 43 1)
(cons 50 0)
(cons 71 0)
(cons 44 0)
(cons 45 0)
(princ)
0 -
That custom command works for me. I added it to my Default and Edit context menus, and that works too.
1 -
OK thanks Anthony, at least I know how to add now.But the actual LISP is not working. It is running because it asks to pick a base point, but then nothing.0
It works perfectly for me. If anything is selected, it just prompts for a base point. If nothing is selected, it prompts for a selection set and then for a base point. In either case, it turns the selection set into a block whose name includes the precise time that the base point was picked.There's no visible change when the block is created, unless the selection set includes a Byblock color. But when I try to select anything in the selection set, the block is selected instead.1
Thanks Anthony, it may be a setting that's preventing this then
0
