please fix briscad dependencies
Could you please report this via Support request?0
Done.
If someone already installed bricscad on linux, please tell us how to solve this:
[doki@lcsCAD ~]$ sudo dnf install ~/BricscadV25.2.05-1-en_US.x86_64.rpm
Failed to set locale, defaulting to C.UTF-8
Last metadata expiration check: 10:55:40 ago on Tue May 13 22:39:00 2025.
Error:
Problem: conflicting requests
- nothing provides libclearlooks.so()(64bit) needed by bricscadv25-25.2.05-1.x86_64 from @commandline
- nothing provides libdeflate.so.0()(64bit) needed by bricscadv25-25.2.05-1.x86_64 from @commandline
- nothing provides libxcb-cursor.so.0()(64bit) needed by bricscadv25-25.2.05-1.x86_64 from @commandline
(try to add '--skip-broken' to skip unistallable packages or '--nobest' to use not only best candidate packages)
0
