Editing fields in Properties
Is it possible to go to next line when editing fields and then pressing Enter. For example, enter X coordinate, press Enter and go to Y coordinate.
  • If you want to change a circle X & Y use Move, pick center point, then type new x,y. 123.45,678.98 and circle will move.
  • OK thanks, but the question asked something different
  • Pressing TAB, will take you to the next line in most sections of the Properties Palette.
  • Thanks David, this helps.
    Would have been useful to have a setting so that Enter can be used since in keyboard number pad
