Civil Points entities in lisp
Hello
A want to create a lisp that uses Civil Points as input (the user selects some civil points and then some things will drawn).
I firstly want to access the civil points using lisp so to get their Easting, Northing, Elevation and Raw Description. Any help to this direction would be welcomed.
Do you mean to string the points using a pt description ? I have started to do something.
Some sample data code. The string 01F will be joined to all 01F's and so on.
1
921.889
4915.96
48.25
01F
2
967.024
4921.68
49.39
01F
3
1045.51
4921.584
52.09
01F
4
1126.961
4941.48
54.36
01F
5
1123.036
5051.04
56.34
01F
6
976.679
5005.819
50.53
TR
7
1047.843
5074.345
56.26
01BB
8
1000.876
5079.2
54.62
01F
9
896.378
5054.56
51.03
01F
10
892.944
4978.88
48.94
01F
11
913.884
4913.589
48.12
01EB
12
991.606
4917.719
50.21
01ET
13
997.129
4919.734
50.32
05F
14
985.194
4955.816
49.03
01ET
15
969.494
4984.416
49.42
01ET
0 -
No I don't mean that.
I mean every entity (line, text etc) has properties (for a line these properties are layer, linewidth, start coordinates, etc) that can be retrieved through auto lisp. I want to retrieve the properties of Civil Points, that can be Easting, Northing, etc.
0 -
use getpropertyvalue
(getpropertyvalue (car(entsel)) "Easting")
0 -
As a side note, I recently added a KD-Tree in Python to aid in working with generic 3d points, but you should be able to use civil points to, since the tree returns the index
import traceback from pyrx import Ap, Ax, Db, Ed, Ge, Gi, Rx, Cv @Ap.Command() def doit() -> None: try: filter = [(Db.DxfCode.kDxfStart, "BSYSCVDBPOINT")] ps, ss = Ed.Editor.select(filter) if ps != Ed.PromptStatus.eOk: raise RuntimeError("Selection Error! {}: ".format(ps)) #get the cv points and ge points, cvpnts = [Cv.CvDbPoint(id) for id in ss.objectIdArray()] gepnts = [cvpnt.position() for cvpnt in cvpnts] # is a nanoflann tree tree = Ge.Point3dTree(gepnts) #search idxs, dists = tree.knnSearch(gepnts[0], 2) for ind in idxs: if ind == 0: continue print( cvpnts[0].easting(), cvpnts[0].northing(), cvpnts[0].elevation(), cvpnts[0].fullDescription(), ) print( cvpnts[ind].easting(), cvpnts[ind].northing(), cvpnts[ind].elevation(), cvpnts[ind].fullDescription(), ) Ed.Core.grDraw(gepnts[0],gepnts[ind],1,0) except Exception as err: traceback.print_exception(err)0 -
Thanks. It works.
Do you know the property name of Point row description? I have tried Pointrawdescription and several other similar names but they don't exist.
0 -
I think there’s a function that will give all the possible properties for an entity
https://developer.bricsys.com/bricscad/help/en_US/V23/DevRef/index.html?page=source%2FgetPropertyValue.htm
0 -
Yes it's dumpAllProperties. Thanks again!
0 -
Also use dumpit.lsp then say (vlax-get obj 'property) it will become one of those must have lisp.
;;; DumpIt ;
;;; Dump all methods and properties for selected objects ;
(defun C:Dumpit ( / ent)
(while (setq ent (entsel "\n pick object "))
(vlax-Dump-Object
(vlax-Ename->Vla-Object (car ent))
(princ)
);(dumpallproperties (car (entsel)))
0 -
This function will print the properties of selected civil points out to the screen
(defun C:CivilPointInfo ( / sset ptEname)
(cond
((vl-load-civil) ; Load the Civil API. requires BricsCAD Pro or greater
(princ "\nSelect Civil points to get info on: ")
(setq sset (ssget '((0 . "BsysCvDbPoint")(410 . "Model")))) ; allow selection of only Civil points
(cond
(sset
(foreach ptEname (vle-selectionset->list sset) ; foreach civil point
(princ "\n---------------------------------------")
(princ "\nCivil Point Number: ")(princ (civil:point-get-number ptEname))
(princ "\nName: ") (princ (civil:point-get-name ptEname))
(princ "\nRaw Description: ")(princ (civil:point-get-rawdesc ptEname))
(princ "\nFull Description: ")(princ (civil:point-get-fulldesc ptEname))
(princ "\nDescription: ")(princ (civil:point-get-description ptEname))
(princ "\nPosition: ")(princ (civil:point-get-position ptEname))
(princ "\nEasting: ")(princ (civil:point-get-easting ptEname))
(princ "\nNorthing: ")(princ (civil:point-get-northing ptEname))
(princ "\nElevation: ")(princ (civil:point-get-elevation ptEname))
(princ "\n")
(T (princ "\nNo Civil points selected"))
(T (princ "\nSorry you need BricsCAD Pro or greater to work with Civil Points"))
(prin1)
)Jason Bourhill
CAD Concepts Ltd
1
