How to switch documents while a command is running
Hello.
I created a command to get points.
    <CommandMethod("test")>
Public Shared Sub test()
Dim editor As Editor = Application.DocumentManager.MdiActiveDocument.Editor
Dim pop As New PromptPointOptions("Select Point")
Application.ShowAlertDialog(editor.GetPoint(pop).ToString)
End Sub
It is not possible to switch documents during user operations.
The "LINE" command allows you to switch documents.(Switching documents will end the command.)
I would like the custom command to be the same as the "LINE" command.
Is there a way to switch documents with a custom command, just like with the "LINE" command?
  • Usually, you would have to run the command in a session context, Caveat, you may have to add document locks.
    Note, if the line command allows for document switching, that seems like a bug
  • hirano
    edited July 2025
    Thank you for your reply.
    I tried "CommandFlags.Session", but it didn't solve the problem.
        <CommandMethod("test", CommandFlags.Session)>
    Using docLock As DocumentLock = Bricscad.ApplicationServices.Application.DocumentManager.MdiActiveDocument.LockDocument()
    End Using
    End Sub
    The problem is occurring in BricsCAD V25.
    →BricsCAD version:V25.1.06
    As a side note, in V19, custom commands worked the same as the "LINE" command.
  • I used the "DocumentToBeDeactivated" event but it didn't work.
    End Using
    End Sub
    <CommandMethod("AddDocumentToBeDeactivated", CommandFlags.Session)>
    Public Shared Sub AddDocumentToBeDeactivated()
    AddHandler Bricscad.ApplicationServices.Application.DocumentManager.DocumentToBeDeactivated, AddressOf OnDocDeactivated
    End Sub
    <CommandMethod("RemoveDocumentToBeDeactivated", CommandFlags.Session)>
    Public Shared Sub RemoveDocumentToBeDeactivated()
    RemoveHandler Bricscad.ApplicationServices.Application.DocumentManager.DocumentToBeDeactivated, AddressOf OnDocDeactivated
    End Sub
    Private Shared Sub OnDocDeactivated(sender As Object, e As DocumentCollectionEventArgs)
    editor.WriteMessage(vbLf & "MdiActiveDocument {0}:", New Object() {Application.DocumentManager.MdiActiveDocument.Name})
    End Sub
    STEP1: Execute the "AddDocumentToBeDeactivated" command.
    STEP2: Execute the "test" command.
    STEP3: I try to switch drawings during the "GetPoint" operation.
    RESULT: The drawing does not switch. The "DocumentToBeDeactivated" event does not occur.
    It looks like drawing switching is disabled. Is there a way to enable drawing switching?
    I'm really in trouble.
    Do you have any information?
  • Its_Alive
    edited July 2025
    Sorry, it seems CAD is becoming stricter with document switching. The only way I’ve found that works is to use the document manager to switch documents.
    @Ap.Command("doit", Ap.CmdFlags.SESSION  )
    def doit() -> None:
        try:
            man = Ap.DocManager()
            docs = man.documents()
            man.setCurDocument(docs[0],Ap.DocLockMode.kNone,True)
            print(docs[0].fileName())
            ps, pnt1 = Ed.Editor.getPoint("\nSelect Point")
            man.setCurDocument(docs[1],Ap.DocLockMode.kNone,True)
            print(docs[1].fileName())
            ps, pnt2 = Ed.Editor.getPoint("\nSelect Next Point")
        except Exception as err:
            traceback.print_exception(err)
    : DOIT
    Drawing1.dwg Select Point Drawing2.dwg Select Next Point
  • Thanks for your reply.
    However, that wasn't what I wanted.
    I did some further research.
    I was able to achieve what I wanted using "BRXSDK."
    It seems this isn't possible with ".NetAPI."
    Please let me know if you have any additional information.
