InPower V1.02.11 BricsCAD V23 Ubuntu V20.04 LTS Installation and Testing
BricsCAD V23 and Ubuntu V22.04 LTS Desktop had mouse issues when BricsCAD "stretch" was used with KVM VM's. Base bare metal machine install of Ubuntu 22.04 seems to work fine. I completed minimal testing with base bare metal 22.04. Ubuntu 22.04 also seemed to be slow.
Ubuntu V20.04 LTS Desktop is working great. This will be the OS for InPower for the near future.
I will put the installation and testing notes here in this thread.
V24 is not working at all, crushing continuously. After several uninstalls and installs now it says your trial is ended in a day. If you install version 24 on ubuntu 22.04 LTS please let me know.1
Still working with V23. Just had the tool bar disappear again. Everything else seems to be working well. InPower V1.02.14 added single phase fault and arc flash. Moved back to Ubuntu 20.04 Desktop LTS due to mouse issues.1
Still have a intermittent crash when selecting two block at the save time for editing. Does not seem consistent as I can select two block most of the time without a crash. Crash seems to happen after working for some time. Like a memory leak.
Save your work!
Other than that, things have been pretty stable with V23 and Ubuntu 20.
InPower Version Log
Ver. InPower 1.02.12 4/2023, Fixed bug due to IEEE2SEC rule.
Ver. InPower 1.02.13 4/2023, Changed displayed one line fault current to show the arcing current
Ver. InPower 1.02.14 4/2023, Added single phase to the model
Ver. InPower 1.02.15 4/2023, Added single phase to the blocks via the *SinglePh attribute.
Ver. InPower 1.02.16 7/2024, Fixed single phase bug where bus voltage was changed by sqrt(3) then changed back, added arcing fault estimate for CalcTime function. Used to estimate the pdev selection.
Ver. InPower 1.02.17 8/2024, Fixed single phase inpower.out voltage printing bug
Ver. InPower 1.02.18 9/2024, Added error check for missing bus
Ver. InPower 1.02.19 9/2024, Added INPRENUM command to renumber copied buses
Ver. InPower 1.02.20 9/2024, Added WYEUNG (ungrounded WYE) to tranformer winding type. Added Octave to FAULTCOMMAND for some formatted print
Ver. InPower 1.02.21 10/2024, Updated INPRENUM. Use INPLOAD then INPRENUM, buses are renumbered, then network devices that are close to the buses are renumbered to match the bus number.
Ver. InPower 1.02.22 10/2024, Add new logInterp function to interpolate between TCC points1 -
any update?
0 -
No, still crashing. I'm in the process of upgrading to BicsCAD V25 to see if that helps
0 -
I upgraded to V25, I can select about 10 blocks, then BricsCAD freezes, if I hit ESC, BricsCAD comes back. No crashes, just freezes up with no action.
0
