TIN surfaces on BIM section plans
Hi,
Starting to learn a bit about bricscad TIN surfaces and I noticed that they don't seem to apear on Bim section plans!
The fact is I can convert to solid, but then I have ugly triangles and loose the power editing tools…
How do you manage to have TIN surface contours on bim section plans?
0
Ok. I found out the problem.
The TIN surface is on a xref.
And bricscad section does not recognize tin surfaces inside a xref file.
If I copy it to the master model it works as expected.0
