find layer and set current
Please,
is it possible in Bricscad, find layer when you click on Layercontrol, then type first later and find very fast layers and set current layer?
When I do that, it goes very slow, and a can't set current layer.
I know work with a filters but it is slow.
Please, it is possiblle work like in autocad?
Tnx.
  • Hello.
    The layer control from the ribbon has, indeed, some limitations.
    This topic is currently under investigation.
    Something of interest could be to use one of the Access or Access 3D toolbars.
    Each of these has a layer control on it.
    The toolbar layer control works fine with typing a few letters and pressing ENTER - the selected layer is set current.
