Draworder command from quad with strange behaviour (not working)
Running the latest V26.1.06
When selecting objects and using the QUAD to change draworder the command behaves very strange and doesn't seem to be working. I'm asked to select objects (command line), but I already did. Something is broke with the draw-order when used from the quad command I think. It seems to be working alright using the draw-order via the command line.
Anyone else experiencing these kind of problems?
Yes I have the same problem, except it also doesn't work from the ribbon or from the menu. Problem started after latest update v26.1.06-1
I reported the bug.
2 -
Same here, noticed it yesterday, doesn't work from the quad or ribbon or menu in v26.1.06, the command appears to be broken in this release, when intiated it ask to select entites and afterwards show some commandline options that suggests the fillet command and the whole thing fails after that.
0 -
Thank you for reporting the bug!
0 -
The problem is forwarded to developers. At the moment I see two possible workarounds:
- run Draworder first, e.g. from toolbar, then select entity;
- another way is to set NEXTFIBERWORLD=1 (type it in the command line) and restart the program.2 -
Thank you very much Osina!
The nextfiberworld=1 really helps for now. Don't know what this setting does, but for now it makes the draworder working again from the QUAD.0
