Layout Tab name as a field-name
Currently using BricsCAD Lite V26.1.05 (x64) .
I wish to string 2 field-names together to make up my drawing number on my title block.
The 1st bit is ok filename = 101-003-SKE-001.dwg.
The problem is with adding the Layout Tab name ….. there is no ?? field-name for this.
From memory AutoCAD has this ??
So if I have 2x paperspace layout tabs called .01 and .02
So %<\AcVar Filename \f "%tc1%fn2">% = 101-003-SKE-001.01 and xxxx-001.02.
Hope that makes sense.
Regards Kim
