LookFrom not working V26
I have BricsCAD Pro V25 on my Windows 11 PC. The other day I installed V26. When I first started using V26 the LookFrom was different from V25. I now know that is the "new" LookFrom. Fine with me as it appears to be a bit better than the V25.
However, yesterday I opened V25 and V26 at the SAME time. I didn't think that was a great idea but this is the first time I upgraded BricsCAD so I didn't think twice. Bad idea! I will never open them at the same time again.
I shut down the system yesterday but this morning when I opened V26 the "old" LookFrom" was displayed. Review of my settings indicated that the new one should be there. Changing system variable USENEWLOOKFROM from 1 or 0 did NOTHING to the display.
I would just let this go and use the old one but the old one does not operate correctly. When the mouse hovers over the LookFrom the image flashes and becomes unreadable making selection of one of the views very difficult. Although if you click in just the right place the view does change so I guess you could say it is half-working!
How can I get the new LookFrom back?
