Python, Local AI and Rag concept
1, Make sure PyRx is installed and pip install lmstudio
2, Download LM Studio
3, find a load a local model your computer can run, I used qwen3-coder-30b-a3b-instruct but it’s quite large, openai/gpt-oss-20b should run on a modern workstation.
4, Upload your documents, maybe some sort of job specification
5, load in a routine that can connect to LM studio. Check lmstudio docs for the details
For one computer, probably just use LM studio, but some small company could have a dedicated machine for inference. Best of all its all private
from pyrx import Ap, Db, Ed, Ge, Gi
import lmstudio as lms
@Ap.Command()
def yeehaw():
    try:
        ps , question  = Ed.Editor.getString(1,"Wuut? ")
        if ps != Ed.PromptStatus.eNormal:
            print("Oof: ")
            return
        model = lms.llm("qwen3-coder-30b-a3b-instruct")
        print(model.respond(question))
    except Exception as err:
        print(err)
  • Another test, instead of using RAG, I fed the data directly into the context window. Not the most optimal way of creating a table. I guess the hard part is building up context from a bunch of lines
    from collections import defaultdict
    import traceback
    #scan for room blocks
    @Ap.Command()
    def yeehaw():
        try:
            blockinfo = defaultdict(list)
            db = Db.curDb()
            for bname, bid in db.getBlocks().items():
                if bname.casefold() != "elev".casefold():
                    continue
                btr = Db.BlockTableRecord(bid)
                if not btr.hasAttributeDefinitions():
                    continue
                refs = [Db.BlockReference(id) for id in btr.getBlockReferenceIds()]
                atts = [Db.AttributeReference(id) for ref in refs for id in ref.attributeIds()]
                for att in atts:
                    blockinfo[bname].append(att.textString())
            question = "please create a table of rooms.{}".format(str(blockinfo))
            resonse = model.respond(question)
            print(resonse.content)
        except Exception:
            print(traceback.format_exc())
  • Okay, last test, would you live here? lol
    import json
    import traceback
    @Ap.Command()
    def yeehaw():
        try:
            question = """Please generate a floor plan of a typical single-story house,
            please only give me the room parameters in the format of a list of 2d points,
            I will then use these points to generate polylines.
            the end format should be JSON, {roomname, list_of_points}"""
            js_anwser = resonse.content
            js_anwser = js_anwser.strip('```')
            js_anwser = js_anwser.strip('json')
            data_dict = json.loads(js_anwser)
            plines = []
            db = Db.curDb()
            for room, points in data_dict.items():
                pl = Db.Polyline(points)
                pl.setClosed(True)
                print("Creating room {}: ".format(room))
                plines.append(pl)
            db.addToModelspace(plines)
        except Exception:
  • Neat experiment. Is that a bay bathroom? Hallway to garage? You should have added room labels!
  • Its_Alive
    edited January 16
    Exactly, DOH! Should have added labels. I had already lost the context and the next generation would likely be different.
    Like with coding, I can imagine drafting in collaboration with AI. Thoughts:
    • There needs to be some mechanism to manage the state & IO:
    • Conversation “why did you make that abnormal sized room? Can you make it bigger” or "I made the room bigger, what do you think?"
    • Data, models seem to do well with JSON, maybe something like { conversation : data }
    • Action, apply/collect data from/to the drawing.
    • RAG, upload design documentation to the model.
    • Context Window, there needs to be a way to edit/prune the context window for when the model starts to go wonky, or to explore chains of thought
    Edit: AI said it would be happy with something like
    "conversation": [
    {"role": "user", "message": "Make the living room bigger"},
    {"role": "ai", "message": "I've increased it to 20x15 feet"}
    "design_state": {
    ..data..
